Originally Posted by
WLIU
The YAK pilot was in an FAA authorized, NOTAM-ed, and ATC coordinated aerobatic box next to an airport. The non-participant came out of the haze and sun at something like 190kts and drove right through the airspace, clipping off the tail of the Yak, losing his right wing and impacting just off the airport. All happened fast enough that the ground observers watching for non-participating traffic did not have time to call the YAK pilot on the radio. And the non-surviving pilot did not make any radio calls about his arrival at the airport.
There are lots of NOTAM-ed airspaces out there that should be approached with caution, not just MOA's. And there are other cautionary aspects of the accident narrative. Too many pilots don't use their radio when approaching an airport traffic area. And some of the pilots that do make "blind" calls and do not listen for responses from the unicom or other aircraft in the traffic area. If the non-surviving pilot had done anything to understand the current activity at the airport, or approached with less speed, etc., the collision would not have occurred. The YAK pilot was operating entirely within the specifications of the FAA authorization for the activity at that location. Not much you can do at near the top of a hammer, with almost zero airspeed, when someone who did not do their homework comes barging through.
Y'all be careful out there,
