Drag racer belts take a lot more abuse than aircraft seat belts. Aircraft belts are evaluated based on condition. It's SFI's recommendation that the webbing be only used for two years. The NTSB has actually looked into it. They've not actually found the webbing to be as much of an issue as other problems in the belt system. These should be caught at annual.
