Results 1 to 7 of 7
Thread: Antenna Question
    Hood River, OR
    Antenna Question
    We are planning on installing an antenna with an antenna lead to connect to a handheld in 3 L-Birds. Any recommendations as to top or bottom antenna location? The ignition system on these airplanes is not shielded. I presume some form of ground plane will be required. Any thoughts on this project?
    Nov 2012
    I use this antenna. It was a simple hookup or install. Nothing special needed and it works great. I did mount mine horizontally and it works ok. But these work best mounted vertical or so they say. Like I said I have no issue with mine mounted vertical.
    http://www.aircraftspruce.com/catalo...nnasystems.php
    Sep 2016
    The one recommended by 1600vw does not require a ground plane. It is built into the antenna. Bottom mounting typically works better when flying and top mounting better when on the ground.
    Nov 2012
    The nice thing about the antenna I posted, it covers all area's without a dead spot above or bellow the airplane. You do need a wooden framed airplane to use this style of antenna.
    Hood River, OR
    I should have mentioned that the L2, L3, and L4 all have steel tube fuselages covered with fabric.
    On my Kolb I mounted the handheld's original rubber duck antenna on the bottom of the fuselage with an extension cable. My Fisher came with a wire antenna like this one mounted on top of the upper wing center section. Both worked just fine.
