Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: VMC
    Quote Originally Posted by Cary View Post
    Here's a really good example of what is not VMC: https://www.youtube.com/watch?v=r2MVDY8o7Bs Be sure to watch to the end, to see how close they really were.
    I notice they made sure not to show a complete N-number there.
    Oct 2014
    Tehachapi, CA
    That would technically be called Vmca. We are sticklers here for exactness.
    Well, exactly per CFR 14 Part 23.149, they call it Vmc :-). No "a", although some folks do use the "a" for airborne, and a "g" for ground.
    The international organization (ICAO) recognizes Vmca as the official acronym and yes "a" whilst airborne.
    CJR / NC26
    Hah! Does that mean that a non instrument rated pilot flying solo can log instrument time?
    Absolutely. Same as an instrument rated pilot not on an IFR clearance.
    Jim Hann's Avatar
    Actually Marc 23.149(f) talks about VMCG (they put it all in caps in the rule)
    Now if you really like letters here is a quote from AC 25-7B which is the guide to certifying your Part 25 aircraft.
    23. Minimum Control Speed - § 25.149
    a. Explanation
    Section 25.149 defines requirements for minimum control speeds duringtakeoff climb (VMC), during takeoff ground roll (VMCG), and during approach and landing (VMCLand VMCL-2). The VMC (commonly referred to as VMCA) requirements are specified in§ 25.149(a), (b), (c) and (d); the VMCG requirements are described in § 25.149(e); and the VMCLand VMCL-2 requirements are covered in § 25.149(f), (g) and (h). Section 25.149(a) states that“...the method used to simulate critical engine failure must represent the most critical mode ofpowerplant failure with respect to controllability expected in service.” That is, the thrust lossfrom the inoperative engine must be at the rate that would occur if an engine suddenly becameinoperative in service.
    But you are correct that there is no official Vmca definition for the US FAA.
    Jim Hann
    EAA 276294 Lifetime
    Vintage 722607
    www.mykitlog.com/LinerDrivr
    Fly Baby/Hevle Classic Tandem
