Results 11 to 20 of 31
Thread: Getting More Volume from a Handheld Radio
    Ron et all.... I was dealing with the same issue the other day - of having a limited volume on a head set/portable - this time for marshaling. So I searched the feeds and ran into your multiple articles.
    SO, I ordered the headset and replacement speakers but the wiring looks a bit different now - I thought I would add the photos here for comparison.
    There is a 3.5 mm jack on the right ear cup as well.
    Wow, that is a bit weird (or maybe wired). Didn't see all the circuit boards in my Rugged Radios headset, but I didn't dig into it very far, either.
    Despite the complexity, it's just the speakers that need swapping. Disconnect the wires to the 300-ohm speakers, solder them to the 8-ohm models.
    However, gotta ask...it's not an ANL unit, is it? Not sure what a speaker switch would do to an ANL unit...nothing good, I'm sure.
    I now have ~10 hours on my converted Rugged Radios headset, and it's been working great. No problem at all, volume-wise.
    Jim Heffelfinger's Avatar
    Ron, No not ANR. Same model as you and also "demo". Does yours have a volume control? 3.5mm jack for input. Not sure of levels or impedence. No owner's manual. I will look on the site. Easy solder job. Use a low wattage iron or you will fry the prints on the boards.
    I don't have it here, but I believe mine has a volume control.
    Personally, I wouldn't bother with the boards. Cut the speaker wires and splice in the new speakers.
    Actually Ron , I just easily unsoldered the 300 ohms and soldered the 8s at the PC boards. - 10 Minutes including letting the station come up to temp and clearing away a spot on the bench. Added an additional sound absorbing layer on the inside of the cups as I put it back together. All good.
    Jim
    BTW : Thanks for all the great work you do for EAA and us.
    BTW - BTW - I am having a dickens of a time putting on the gel cup seals. I even had the Rugged guys send me a photo tutorial. Still having a hard time......
    Man, I can tell you're not in my workshop. 10 minutes wouldn't even get you down through enough layers to see the top of the bench. I've forgotten what color it is.
    I had a hard time, too...took persistence and a lot of Finnish swear words. I think I got one short bit started, then pinned it in place with my thumb and used a skinny screwdriver to encourage the rest of it.
    BTW, it occurred to me too late, but...try heat. Use a hair dryer to heat up the cub seal before trying to put it on.
    RE ear cup seals - I set them out in the sun for 30 minutes - in-sun temps reading 114 today. ( 99 in the shade) I was able to get them on but it was quite a trial. Not for the weak of hand. After all that I was not able to get the 3.5mm input to the speakers. Just nothing coming out. So...... I pulled it all apart looking for a fractured wire or something. Head set worked other than that. At first I was annoyed as the volume was actually weaker than the volume in the regular headset going through the same radio - comparison test - until I realized the on headset volume was turned way down. Pheuw. Have to call tech at Rugged to figure out why I do not have the aux input feature. Apparently they do not have a schematic diagram at hand for the headset. I may have to make one from wire tracing.
    FWIW - the speakers are in parallel so I am getting a 4 ohm resistance reading at the plug.
    Headset volume has been a problem in my very windy and noisy Fokker D.VII replica. I use a Yuasa handheld and Lightspeed QFR ANR headset but still have problems hearing some radio transmissions.
    Until today. Following Ron's suggestions, I ordered the 42TL004 miniature audio matching transformer from Mouser and wired it onto the headset adapter. Wow...lots more volume! I was a little concerned about proper matching because the transformer input is 10 ohm and the radio specs say audio is fed to a 16 ohm speaker. But it seems to work fine and I hope there are no long-term issues with the small mis-match.
    Highly recommended mod and much appreciated!
