You got it. My assumption was....... wait for it.............. it worked at one time. As noted By Dana and DaleB it could never work as wired. The input from the Aux source just stops. Solution...........
These were "special" and discounted heavily.
In another life - I was an Navy ET. We troubleshot equipment based on the assumption it worked correctly at one time. I then worked for Sanyo building consumer audio equipment. As technicians we assumed it was assembled wrong first and then went to standard troubleshooting methods. This is one of the latter.
