Results 1 to 9 of 9
Thread: Cessna 150 spinner wanted
    May 2012
    Looking for complete propeller spinner installation parts for a C150 thru C150K. Also would consider a used / serviceable Sensenich C2401 spinner kit.
    Feb 2012
    Barrington, IL
    Wag aero sells them....
    May 2012
    Won't work
    Quote Originally Posted by Kurt Flunkn View Post
    Wag Aero spinner kit is for use with a prop spacer. Without the spacer, the aft disc contacts the cowling because the mounting flange faces aft. Prior to the C150L, all aft mounting disc flanges faced fwd. I have a C150B.
    Feb 2012
    Barrington, IL
    Try Yingling in Wichita ....
    May 2012
    Lots of bucks. Over $1100. Was thinking of something in the used/serviceable price range. Was hoping someone would have a set they didn't need anymore.
    Feb 2012
    Barrington, IL
    You could try the salvage yards. Places like white industries, Texas aero salvage, Wentworth, etc. This type of part usually won't come with an airworthiness tag....
    May 2012
    I now find an interesting item of note. It seems that I can't even order a new Sensenich spinner kit, C2401, anywhere. Sensenich's web site will let you put it in your cart, but will not let you check out. Aero- In Stock is the only other place I found that sells the C2401, but they out of stock and would need to back order. The salvage yards have nothing.
    meglin's Avatar
    Aug 2015
    Kharkov
    It may be useful for your aircraft?
    Best regards, Vladimir Meglinsky
    My site: http://propeller.simplesite.com/
    If I had a 150B it be skull cap installed and flying.
