Results 1 to 10 of 12
Thread: Paint Peeling Challenge
    Aug 2013
    Ok. So i got the rear of the plane all primed and painted (on the inside) and while I was blowing out some aluminum shavings, I ended up seeing the paint peel off.
    The surface was cleaned, the paint did not ripple - looked fine. Just when a standard air blower off my compressed air tank was used, it peeled up.
    Thoughts on a cause? I used a solid etching primer (Dupli-Color Pro Automotive Primer), and then a top coat with a basic Rustoleum pro black enamel.
    Jan 2013
    Kenosha, WI
    Did you use a self etching primer under the paint?
    Aug 2013
    Yes, I used a solid self-etching primer (Dupli-Color Pro Automotive Primer).
    http://duplicolor.com/product/self-etching-primer
    All I can think of is that I should have buffed with a good sandpaper prior (sigh - its on my checklist...)
    Quote Originally Posted by bdflyer View Post
    Self etching primer should stick much better than *that* even to un-scuffed metal if the metal is clean. That said, a scuffing with scotchbrite is recommended and will promote adhesion.
    I'd do some test coupons to see if that primer sticks to scuffed aluminum before I used it again.
    Wachapreague Va.
    Red scotchbrite pad not sandpaper. Steps are as follows , Clean and degrease, scuff, clean and degrease, acid etch, alodine, epoxy primer, topcoat. Oversimplified but you get the idea. Looks like the primer did not stick at all. Start over. Boy that bites.
    Duplicolor aerosol products are not what you would use in the same sentence as quality. From the SDS it looks more like flat lacquer, lots of solvents with just a touch of pigment. From the photos not much etching took place.
    I would avoid using sandpaper and even scotchbrite on a new surface.
    Matt Gonitzke's Avatar
    Wichita, KS
    What's wrong with scotchbrite? Lots of factory-built airplanes have parts roughed up with scotchbrite wheels before primer is applied.
    Aaron Novak's Avatar
    Oshkosh, Wi
    Quote Originally Posted by vaflier View Post
    Yep thats the best process, anything else is just taking shortcuts.
    Quote Originally Posted by Matt Gonitzke View Post
    It is the same as sandpaper, the paper backing replaced with spun polypropylene fiber. They both use aluminum oxide as the abrasive.
    It's like saying: "Don't drink water - use this H2O product instead!"
    That's well and good but an alternative method is to simply clean the surface with the proper solvent and spray on a product like "Don't Punt" Verri Prime. It can etch and adhere to a porcelain enamel finish with minimal prep (clean and degrease). Having used the old methods for ~40 yrs. I'm inclined to embrace technological advances in this area.
