Could you please email me your activation key so I can check it?
Just started the download/install process. Got the 1st ~20meg batch of install files. When I clicked on 'sldIM.exe', I was given 4 choices: individual, Administrative image, server products, and 'download and share all files'.
I'd like to install on both my home desktop and my shop desktop (both on the same LAN). Anyone know which type of install to pick?
Thanks,
Charlie
Tried several times to install but a third of the way it stops and shows "internal error....Windows installer.... did not run as expected...contact technical support.... need to provide installation log files (which I have saved)..
Thanks for your help,
Karen
Sorry for the delay in responding. Please confirm via email if any of the solutions I recommended via phone work. In the meantime, I will check the log file you send for a probable cause.
I registered with my new number. Did the lengthy download. When I try to run the software I get a message concerning the SQL Server. I don't understand what that means.
Do you have an error code? Can you email the install log so I can check errors? Installation logs are typically here: C:\Users\%username%\AppData\Roaming\SOLIDWORKS\Ins tallation Logs
I'm no expert on Windows 10 but maybe this will help:
Before you do something drastic (like re-installing W10), try going into the registry editor (regedit) and choose Edit>Find>solidworks.
Delete the first entry regedit finds and then press Fn/F3 to find the next instance and repeat. There are quite a lot!! (I found about 50 before I stopped looking) But sometimes they appear under folders that you can delete all-at-once.
Having said that I've never been in your situation before, I've never done the above suggestion before, and I'm not even sure it will work. So let me know the result before you call your solicitor
Regards, Jeffrey
