Need a ride from MKE to Oshkosh on Thursday the 28th. Any suggestions?
I had a last minute change of plans which allows me to make it to Oshkosh, imflying into MKE Thursday at 3PM. Any suggestions on how to get to Oshkosh? I only need a one way ride, I already have a flight home direct from Oshkosh.
Lamers Bus Lines has a daily bus route from MKE, with stops at either the Oshkosh airport terminal or the university campus (if you are staying at the dorms). Information on the route is at the link below.
http://www.golamers.com/services/lam...e-daily-route/
According to their schedule, the route leaves MKE at 2:30 pm, so if you could get into MKE before then, this might be an option.
