Originally Posted by
spongebobiwan
Todd,
I thought I'd pass on this little tidbit. Perhaps it can be helpful in some way. I was (and still am actually) watching the Live Webcam -Around the Grounds and they are interviewing the Emery Riddle people. At the same time, somebody with EAA Radio was also broadcasting part of the interview using Periscope.
What I observed is, that the Around the Grounds Live Webcam has/had severe audio issues. While the camera image is excellent, the audio keeps cutting in and out. You can hear the audio clearly for approximately 5 or 6 seconds or so, then it cuts out completely for a few seconds. It repeats this process continually.
On the other hand, the Periscope broadcast while not nearly as clear and sharp of an image (a bit fuzzy or blurry, actually), the audio is nevertheless pretty solid. There is very rare or occasional stuttering in the audio, for the most part it is steady enough to listen to and comprehend easily, unlike the Around the Grounds.
Just thought I'd pass this on for whatever it's worth as to troubleshooting or tweaking.
Russ
