My head hurts....... Lol.
Rick
But seriously thank you to ALL of you for your advice and info....
Rick
Ron, since your 1st paragraph is basically repeating my 2nd paragraph, I assume the 'slightly off' is referring to your 2nd paragraph. I didn't mention the whole E-SLA situation because, if memory serves, the E-SLA category is mostly for former "fat" Ultralights and the 2-place versions of them that were for training. I'm now guessing a bit so please correct any error, but I thought FAA needed a place to put them and so made the Experimental Light Sport category. Because the original post sounded like he was interested in a bit larger & faster machinery than those craft, I just skipped the E-SLA bidness.
Russel Green
You had a good summary, but at one point you said:
"HOWEVER, if you purchase a used S-LSA, you can take a 120-hour course to become legal for all maintenance and annual inspection on your S-SLA. "
The 120-hour course lets you annual ANY S-LSA, not just one you own.
The E-LSA category covers the former fat ultralights, but it's much broader than that. For instance, you said:
"Where the confusion comes from is regarding S-LSA. These are aircraft purpose-built for LSA category, usually sold as a kit or ready-to-fly from the factory. "
S-LSAs are produced, ready to fly by the company, not by individual buyers as kits. The company can sell the same aircraft as a kit, but when completed, it can only be licensed as E-LSA. Similarly, the owner of a S-LSA can have his airplane re-registered as an E-LSA. He can then do his own annuals, if he takes the 16-hour Light Sport -Inspector course.
Here's some artwork that I hope helps explain it...
And a bit more on the maintenance/inspection issue:
And there is your next magazine article on a widely mis-understood subject. Or has it allready been published?
Good job. Thanks for taking the time.
BJC
I'm off to purchase a pitchfork and suitable materials to construct a torch for the use of the word "Annual" when describing the 12 month Condition Inspection of Experimentals.
It's a long march from here to there, so expect me in about six months.
Very nice graphic to explain stuff for us monosyllable types, Ron!
Ron,
Forgive my ignorance ( read that as stupidity), but does the 120 hour course allow repair and inspecting ANY aircraft that is not tc'd but falls in the lsa category. For example, I purchace a completed Kitfox IV, can I do maintenance and condition inspection ( correct terminology for Frank... I am a bleeder) on it?
Thanks
Rick
Best start with the FAA.
From http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/4db2c5cd655cb3cc86257647004af4ee/$FILE/AC%2020-27G.pdf
17. Becoming a Repairman of Your Amateur-Built Aircraft. You can get a repairman certificate under certain circumstances. However, the only privilege this certificate gives you under 14 CFR § 65.104, Repairman certificate—experimental aircraft builder—Eligibility, privileges and limitations, is to do the annual condition inspection.
BJC
Ok,
so let's use a Rans s-7 for example. They had a kit that was not s-lsa but now it is marketed as s-lsa. In the eyes of the FAA are they two different aircraft? Am I getting this all hosed up? Could I repair one but not another?
Thank you for your patience
Rick
