Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Can I fly IFR in VMC if my instrument rating is not current?
    Netherlands
    Another way of flying somewhat IFR, not being current or even close, is the following: you file VFR and use the phrase "I accept vectoring". At least that works well in Europe where IFR is incredibly complicated to get (you need to be able to explain in detail the systems of an Airbus 320 as an example although you fly an RV-12 or something). EU ATC likes it when they can give you some vectoring and altitudes due to the dense traffic and their virtually non-control over VFR traffic. That includes flight following, obviously, a great safety item.
    US ATC isn't supposed to vector VFR traffic outside of certain terminal airspace. In fact, except in terminal areas, vectors are uncommon even IFR. They won't typically give you vectors even if you state you are willing to accept them. If you want vectors to an instrument approach intercept or the like, ask explicitly for what you want. They'll give you the instructions with a healthy "Remain VFR" caveat.
    Mar 2018
    Gatineau, Qc, Canada
    What about aneasier IFR rating for private pilots? The european EIR (Enroute IFR Rules= T-Oin VMC, fly in or above the clouds and land in VMC). Maybe not less intrumentsin the cockpit but less study and training. Who needs an IFR ticket when 80% ofthe time the IFR flights are done in VMC.
    Transport Canada and COPA are studying the case. Andre.
    Been discussed. Likely not gong to happen. Obtaining the instrument rating is not hard. Maintaining proficiency in it is the hard part. Can't see watering it down.
