Results 1 to 10 of 12
Thread: Low Wing Pilots: What do you do for shade?
    FastEddie's Avatar
    NW Chicago Suburbs
    I just sold my high-winger and picked up a low-winger, and am planning to camp with my plane as usual. My favorite part of camping with my plane was sitting in the shade under the wing and watching the afternoon airshow after a day of being cooked in the sun.
    Now, I'm gonna need to bring something else to sit under. Any suggestions for a lightweight, easy to setup/takedown solution that will fit in the back of a Bellanca Super Viking?
    I don't want to keep something setup while I'm away from the plane due to the risk of damage to other planes if a storm comes thru and blows it away.
    Search for portable or pop up sun shade. There are quite a few products on the market.
    Bob Leffler
    RV-10 Flying
    www.mykitlog.com/rleffler
    gbrasch's Avatar
    Arizona
    Won't provide shade, but I used one of these, very small and lightweight and couldn't believe how comfortable it is. https://www.rei.com/product/877258/rei-flex-lite-chair
    Glenn Brasch
    KRYN Tucson, Arizona
    2013 RV-9A
    EAA member since 1980
    www.airportcourtesycars.com
    Plenty of room under the Navion wing to sit. But I typically park the plane in the shade anyhow.
    EAA Staff Tom Charpentier's Avatar
    Sep 2012
    To Ron's point, you just need a bigger low wing
    Tom Charpentier
    Government Relations Director
    EAA Lifetime #1082006 | Vintage #722921
    Larry Lyons's Avatar
    Stockton, IL.
    Get someone with a high wing to go along, go in as a flight of two and park together. We usually have 5 to 7 planes and at least one is a high wing. He parks closest to the flight line and we all sit there. Honestly we also take along a pop up sun shade that we stake down and leave up until there is a threat of weather then we collapse it.
    No matter how far you push the envelope; its still stationary!
    Mar 2016
    Rockford, IL
    Don't know how much wing clearance there is but you can take a lawn chair and cut the legs off very short so you just don't touch the ground while sitting on it and then you only need 30" or so for the average person.
    Bill H.
    Quote Originally Posted by griffin800 View Post
    I bought one of these...
    http://spenceraircraft.com/pilot-sho...odel-7789.html
    ... and shortened the legs by four inches. Plane sits high enough with enough dihedral to let me sit under the wingtip. Yes, it's a bit less stable, but I won't have far to fall....
    The advantage of this chair over a normal lawn chair is that it disassembles to a package only a bit larger than a shaving kit. Makes it easier to stash inside a single-seater.
    We found an inflatable sofa we used to blow up and leave under the Navion. The biggest issue was there was no convenient way to stake it down so unless someone was actually sitting in it, it wanted to migrate in the wind.
    Joe Delene's Avatar
    Wisconsin
    Lay under the low wing. If the sun isn't right overhead, there will be some shade from the fuselage. You should be off and about midday anyway, by evening it won't matter.
