Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Weather briefing sites
    The FAA does have the QICP program. However, as aluded to above, for most of us we just need to be assured that our provider is "good enough."
    turbo's Avatar
    Sep 2011
    I use weathermeister.com. It has the nicest presentation of any of the sites I've used.
    ditto.
    Ed DArcy 'Turbo'
    R-44 N7511G 1,300 hrs / RV-6 N26ED 4,700 hrs / helicycle 100 hrs
    Stuart, FL Hartford,Ct Virgin Gorda, BVI
    gbrasch's Avatar
    Arizona
    Quote Originally Posted by turbo View Post
    ditto.
    There is (was?) an issue with weathermeister that was brought to their attention some time ago that they never fixed to my knowledge. If you get a weather briefing, it will only give you NOTAMS along your route of flight UNLESS you are within a close physical distance to the actual center location. May not seem like a big deal, but if you want to get the big picture in case of a deviation, you will not. They were very unresponsive to suggestions and to fix another bug that deleted a lat/long if you edited your route. I use Foreflight myself.
    Glenn Brasch
    Tucson, Arizona
    2013 RV-9A / 1952 Piper Tri-Pacer
    EAA member since 1980
    www.airportcourtesycars.com
    www.facebook.com/airportcourtesycars
