Results 1 to 10 of 13
Thread: Weather briefing sites
    Apr 2016
    Fort Worth, Texas
    So I am curious as to what you folks use for your weather briefings. Do you still call the FSS? Do you use multiple different sites or just one? If so what are they?
    I personally have found that the Lockheed Martin FSS website is excellent. It gives you exactly what a briefer would give you over the phone. You can get the info in plain English as well.
    https://lmfsweb.afss.com/Website/#!/
    So what are you folks using?
    I use weathermeister.com. It has the nicest presentation of any of the sites I've used.
    Marietta, GA
    I use
    wunderground.com
    and
    http://www.aviationweather.gov/adds/
    They have different strengths, but both provide very useful information.
    Auburntsts's Avatar
    Tampa, FL
    I use a combination of sites starting with the general public use sites and get more aviation related the closer I get to departure. i hate to admit it but I still use CSC Duats vice LM's site--just habit. Here's some of the other sites I use:
    https://www.wunderground.com/
    http://rucsoundings.noaa.gov/
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
    FA40
    Preferred briefing site? Latest info I heard during forum at Sun n Fun given by CSC duats folks indicated the only FAA/NTSB recognized official briefings come from FSS and/or Duat vendors CSC and LockheedMartin. Anybody else is repackaging the info and while valuable, is not recognized as an "approved" briefing. True or false, not sure, but FSS or either Duat will show as a valid brief so recommend you use one. Who do I use? I've been using NOAA, L/M, found CSC is easier for local briefs so will start using them for that. Also Avare charts the Notams well, AviationSentry is handy if you have a subscription, and AirNav is great for planning fuel stops on cross countries. Which do I prefer, straight slot or Phillips? Both are great tools but choose the one that fits your screw.
    updated 2 jul - i have discovered that Foreflight also records one's briefing and it uses FSS/DUAT vendor sources so it meets the sniff test.
    Byron J. Covey
    Guest
    I use http://www.usairnet.com/cgi-bin/laun...=KLEE&state=FL but not for an official briefing.
    Also use ForeFlight to get current weather and forecasts.
    BJC
    Auburntsts's Avatar
    Tampa, FL
    So I went back and checked out the Lock-Mart site as it's been awhile and really liked it. I think I'll start using it vs CSC Duats.
    PP ASEL - IA
    EAA Lifetime Member
    WAR DAMN EAGLE!
    For long range forecasts, I use the Weekly Planner https://weather.com/maps/planner
    And NWS Graphical Forecast http://graphical.weather.gov/sectors...?element=PoP12
    And Unisys Weather http://weather.unisys.com/mos/mos_de...hp?inv=0&t=12h
    The day of, I start with the FAA TFR Map http://tfr.faa.gov/tfr_map_ims/html/index.html
    Then ADDS, sometimes USAirNet, Future Radar https://weather.com/weather/radar/in.../USWI0524:1:US, Hourly Weather https://weather.com/weather/hourbyhour/l/USWI0524:1:US
    Then Duats for my official briefing.
    Jan 2016
    So IL
    What is a legal weather briefing?
    http://ipadpilotnews.com/2016/03/qui...ther-briefing/
    FA40
    Quote Originally Posted by flytoboat View Post
    An official weather briefing is the one you can prove presented the info you needed to have. Or should have but didn't present the info that would have prevented your weather-related event. Depends on which side of the courtroom you're on. Disclaimer - this is neither an "approved" nor "official" opinion
