Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Long EZ
    Oak Harbor Wa
    Long EZ
    who is the go to guy for a long EZ questions?
    I have over 500 hours in one I bought. Flying partner has over 1000 in his. What do you want to know?
    Or you could try here: http://forum.canardaviation.com/index.php
    but 80-90% are builders, just theorizing and like to post a lot rather than truely knowledgeable....2 or 3 are very knowledgeable!
    Some very experienced canardians here: http://www.ez.org/smf/index.php?board=2.0
    Oak Harbor Wa
    Quote Originally Posted by flyingriki View Post
    I What do you want to know?
    Things about building, and getting plans.
    Some sources:
    www.canardfinder.com he can find anything related to canards including plans, long rudder plans, Roncz canard plans etc.
    http://forum.canardaviation.com/showthread.php?t=5200
    http://www.dragonaero.com/RAFCDROM.htm
    http://www.eurekacnc.com/products.htm
    http://www.cozygirrrl.com/aircraftparts.htm
    The guy that built mine owns Anacortes Marine Radio near you. If you actually build - he may be helpful. A lot of people buy partially finished projects. These seem to be a good way to get a jump on the build. The problem is, unless you are reasonably familiar with the skills and techinques already, you don't get to work your way up the learning curve in a safe manner that was built into the plans and sequence. You will also need all the Canard Pushers related to the LongEZ for all the 'rest of the story' in constructing one.
    Good luck.
    Oak Harbor Wa
    Some sources:
    Good luck.
    I have experience with Fiber Glass I worked the Marine industry for several years building boat hulls, and have a ATA in marine tech..(VA bennies)
    I know Anacorties Marine Radio, didn't know he built one. thanks for the links
    Mike Switzer's Avatar
    Central Illinois
    Tom - this link has pretty much everything you need in the first post plans, templates, etc that someone scanned in to pdf format.
    You will also need all 80 of the Canard Pusher newsletters, if you can't find someplace to download them I can copy them for you, they fit on 2 CDs
    The original plans are not the greatest in the world, my project is based on a Long EZ & it took some doing & lots of cross referencing in the plans to get the data that I needed put in Autocad.
    Oak Harbor Wa
    I looked at that project, (impressive) it's all in windoz, My Mac has a problem with that.
    Oak Harbor Wa
    Are you telling me that you have all diagrams, plans, and templates in auto cad and can print them?
    Central Illinois
    Quote Originally Posted by Tom Downey View Post
    No, I just did it to the point to where I needed to be to get the critical structural dimensions & wing profiles in before I started incorporating the dimensional changes done by Niel Hunter & Tim Crawford for their larger versions
    Mine is going to be tube & fabric (with some modifications for baggage space) so once I got the original dimensions in I started modifying things from there
    I have all the basic locations in, but giving a conservative estimate & considering the quality (or lack thereof) of the original plans & would guess it would take 80 - 160 hours more to get the whole original design in autocad. (And I never learned 3D autocad, by the time it came out I was in management, so I still do 3 profiles & an isometric, and section views)
