582 rotax bing 54 jetting
I have a new 582 blue head that i need to get jetted. i have looked around and found what main jets, and idle jets, but am not sure what i need for jet needle and needle jet.
my strip is at 8040 feet, 90% of my flying will be up from there, but ocassionally i might drop down to the desert at about 4500 feet. my plan was to jet for 7500' at 50 degrees, if i decide to drop down to the desert i would rejet for that trip. in the mountains here, most if not all of my flying will be early mornings, even in the heat of the summer morning temps are 40's to 50's mid day highs can reach into the high 70's to low 80's
according to what i have found i need a main jet of 150 or 155, an idle jet of 50, but i do not know what i need for the others.
can someone get me going in the right direction?
