Results 1 to 10 of 18
Thread: Should an annual IPC be mandatory and require use of simulators?
    Should an annual Instrument Proficiency Check be mandatory,require a minimum flight time and use of a simulators?
    Auburntsts's Avatar
    Tampa, FL
    Although I see goodness in an IPC, I'm not for making it an annual requirement. But if I did I would definitely be against setting min hours and use of a sim.
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
    FA40
    Quote Originally Posted by Radek.cfi View Post
    No.
    No.
    gmatejcek's Avatar
    Indiana
    Um, NO.
    Thumbs Down
    No.
    no
    Good discussion.
    It is funny, somehow I was expecting this kind of response after I included "mandatory" in my question. I am not going to tell you yet if I agree or disagree with this question but would you mind telling me: why not?... anybody?
    Auburntsts's Avatar
    Tampa, FL
    I simply don't see how adding more seemingly arbitrary requirements adds any value to the process.
    PP ASEL - IA
    EAA Lifetime Member
    WAR DAMN EAGLE!
    I think the question is asking too much at one time. I'm not against an annual IPC. I'm not against a minimum hourly training requirement. I'm not against the use of simulators. But when it's all rolled into one question with no wiggle room, the answer is no.
