I have bought a used varieze, it is located in Canada, I'm not flying it down. (we will trailer it home)
What I have discovered so far.
It was made and registered in the US, once upon a time it had a N number, it was exported in 2003, and now will be imported back to the US.
I have all the paper work that was used to build, and register, including the original letter of limitations.
The Canadian owner will send Transport Canada the letter to de-register it from their data base. Then transport Canada will inform the FAA that it has been exported to the US. This allows the FAA to register it here.
Things I must do:
Have the seller sign a bill of sale to me.
request a N number (or maybe reinstate the old one) I'm not certain it is still available. place that on the aircraft.
get it inspected as per the "Condition" inspection.
request the FAA or a DAR to issue the Airworthiness certificate.
Here is the question.
Did I miss any thing ?
Will I be required to fly off any time ? as in phase 1 testing?
How do you get checked out in one? (you can't see anything from the rear seat)
Any advice? I'm treading on unfamiliar ground.
