Cessna 150 interior plastic
Looking for early Cessna 150A thru 150C interior plastic panels.
www.planeplastics.com
Pricey, but a great product.
I remember reading an article years ago where repairs were done to these type of panels. May be an option for you.
Basically they used some sort of putty or epoxy to make a mold of the texture pattern in an undamaged area. Then using that mold, they made the repair using an ABS slurry (legos or other abs dissolved in MEK). After painting, the repair was perfect.
Early 150's did not originally have much plastic on the interior. Plane Plastics and Texas Aeroplastics are the most common suppliers of aftermarket interior parts.
