Did you disconnect the fuel from the carburetor to do the test? If so, do you have a drain plug in your carburetor float bowl? If so, redo the fuel flow test through the bowl drain, the blockage could be in the carburetor. It could be the float needle, and some carburetors have an inlet screen that could be clogged.
