Results 11 to 14 of 14
Thread: electric powered ultralight
    JoeM's Avatar
    Perryville, MD
    Belite is showing an electric motor in their Skydock, i'm not sure if they've flown with it yet.
    http://beliteaircraft.net/skydock/
    Joe Mikus, MSgt USAF (ret) Avionics Tech
    Perryville, MD
    Student Sport Pilot
    Quote Originally Posted by Byron J. Covey View Post
    Yup, that is a big hurdle for someone wanting to make money off of a new electric design.
    I would love to see an E-AB design, either scratch build or kit, for an electric airplane.
    BJC
    You can get an EAB kit from Earthstar http://www.thundergull.com/. I expect Randall Fishman would also assist with parts for an EAB electric. These would require a PPC but that should not be a big roadblock. The same for the EMG-6 from Rainbow Aviation.
    That gives you three choices in addition to build what you want. Tesla motor and batteries would make a great project. Alternatively, you could move to China. They are developing electric aircraft. However, they too suffer from not having a place to fly them.
    Mar 2016
    Rockford, IL
    electric ultralight
    Quote Originally Posted by aeroschmitz View Post
    Has anyone been tinkering with electric ultralight flight?
    There is an electric ultralight, seems to work pretty well, even on floats:
    https://www.youtube.com/watch?v=Se7bQ16bph4
    Bill H.
    You all are on 5 different pages.
    Question was about "ultralight.
    Answer yes. Many. Batteries are included empty weight. This killed the EMG 5 ultralight. EMG 6 is viable in many variations. Other projects have been mentioned. Turn key UL, No.
    Morph to LSA. FAR Part 1
    "Light-sport aircraft means an aircraft, other than a helicopter or powered-lift that, since its original certification, has continued to meet the following:
    (1) A maximum takeoff weight of not more than—
    (i) 1,320 pounds (600 kilograms) for aircraft not intended for operation on water; or
    (ii) 1,430 pounds (650 kilograms) for an aircraft intended for operation on water.
    (2) A maximum airspeed in level flight with maximum continuous power (VH) of not more than 120 knots CAS under standard atmospheric conditions at sea level.
    (3) A maximum never-exceed speed (VNE) of not more than 120 knots CAS for a glider.
    (4) A maximum stalling speed or minimum steady flight speed without the use of lift-enhancing devices (VS1) of not more than 45 knots CAS at the aircraft's maximum certificated takeoff weight and most critical center of gravity.
    (5) A maximum seating capacity of no more than two persons, including the pilot.
    (6) A single, reciprocating engine, if powered.
    (7) A fixed or ground-adjustable propeller if a powered aircraft other than a powered glider.
    (8) A fixed or feathering propeller system if a powered glider.
    (9) A fixed-pitch, semi-rigid, teetering, two-blade rotor system, if a gyroplane.
    (10) A nonpressurized cabin, if equipped with a cabin.
    (11) Fixed landing gear, except for an aircraft intended for operation on water or a glider.
    (12) Fixed or retractable landing gear, or a hull, for an aircraft intended for operation on water.
    (13) Fixed or retractable landing gear for a glider. "
    Now are there other questions?
    If all goes well I will have a turn key production electric ultralight available for sale within about 2 months.
