Results 1 to 4 of 4
Thread: Polished Aircraft and Paint
    Ok, so I have a stupid question. I have seen some beautifully polished aircraft with painted details. My question is, is the entire aircraft polished before or after paint. I know it is a stupid question, but I have always been curious. It would seem to me that if the plane was polished before that the paint adhesion would be reduced.
    Thanks
    Rick
    prasmussen's Avatar
    Feb 2012
    2OH8
    Self-etching primer over the polished surface maybe? I had a polish that left a silicone coating behind so that might be an issue.
    The journey is the reward.
    I've wondered the same thing. My guess is they do the priming/painting first, and once that's done they polish the whole thing.
    crusty old aviator's Avatar
    Jun 2012
    You can't get here from there
    We always roughed out the location of the trim stripes with masking tape, then polished the plane around the tape, then we washed everything, masked off the stripes and numbers, scuffed up the paint areas with Scotchbrite pads, recleaned, and shot the primer and top coat. After the paint cured, we buffed and waxed the whole plane. There are probably other sequences that would work, too...
