I would like to build a replica P-51 full scale out of composites. I am wondering about a few things.
1) Is there a newer book like Mr. Martin Hollmann's Composite Aircraft Design? That is a great book, but I am wondering if there has been another person in the last 20 years that has expanded on the content with the changes in the composite world.
2) The P-51 has a stall speed of 87kn. This is higher than the FAA allows for homebuilts, or is there a way to keep that stall speed? Otherwise weight and wing design will have to drastically change which would ruin replica nature of the aircraft.
3) What happens if a plane is homebuilt that does not meet the 60kn stall speed of the FAA? Even if you have designed the aircraft to stall at 60kn, and then build it and it is found to stall at 65kn. What happens?
Thank you for the time and any information you can provide.
