Thread: C120/140 skylight upholstry
    May 2012
    I am trying to figure the best way to attach the vinyl headliner fabric to the Cessna 120/140 skylight window retainer frames. The C120/140 parts manual indicates a p/n 0413181 "clip - upholstery", but gives no clear picture of a clip. The clip p/n is no where to be found on the internet. Anyone know the standard or preferred trick ?
    Eric,
    I just finished installing a headliner in my Cessna 140; here's the answer to your question. The stock skylight retainer frames have a formed "lip" all the way around the periphery of the skylight. To use that feature, it is necessary to build an .016" or .020" sheet aluminum piece that will "snap" behind the formed lip on each skylight frame. Then, those pieces are glued to the inside surface of the headliner fabric in the correct positions, the headliner fabric is cut out and folded around the inside of the aluminum pieces, and the fabric/aluminum piece sandwich is snapped into place around each skylight frame. The dimensions of the cutout in the aluminum pieces are fairly critical--too small and it won't snap in place; too big and it won't stay. And, you have to allow for the thickness of the headliner fabric. The fore/aft and side/side locations of the aluminum pieces are also critical. I'd suggest a couple of things: 1) join the Cessna 120/140 Association (http://cessna120-140.org/)--it's a great resource--and 2) buy Lorraine Morris' C140 headliner installation video (http://www.skywardmedia.com/catalog.htm). Of course, if your airplane does not have the stock skylight retainer frames, you are on your own! Good luck!
    May 2012
    Michael;
    Thanks for the info. My project is actually a C150B in which I installed C120/140 skylights under a field approval using standard C120/140 window retainer frames. I had Airtex make a standard C150B headliner leaving an open area for me to cut out the skylight openings. They wouldn't cut the openings. After reading your suggestions, I stared at windows for half an hour. I came up with something similar. I took a scrap piece of my headliner material and inserted it into the formed lip using a dull putty knife. I then inserted a piece of #18 mil spec'd aviation electrical wire into the formed lip over the headliner material, which acted as a "snap in retainer". It holds very well. For longevity, one could apply some glue before inserting the material into the lip. I have only tried this on small pieces of material (4" length). I will try this on the full headliner in a couple of weeks. Hopefully the retainer frame lip openings are even all the way around.
    Feb 2017
    Findlay, IL
    Terrific
    Quote Originally Posted by Eric Brown View Post
    Michael;
    That sounds like an excellent idea. It's been about 5 years, I'm wonderin if you're still a member, and if so, does it continue to hold.
    Thanks...
    May 2012
    I finally got the airplane in the air this July. It's still holding.
