Any "expert" knowledge out there to answer my questions?
I have a Viking/Honda engine in my Zenair which uses regular automotive $6 oil as specified by the manufacturer.
My Lycoming powered Grumman calls for $12 aviation oil.
For the life of me I have a problem seeing the difference. Well yeah,,,,,6 bucks x 8 liters = $48
Is the bearing clearance or seal composition different. Do they react differently at altitude. Do people in Denver use special oil? What oil do the air cooled VW derivative engines use? Or is it because WE HAVE ALWAYS DONE IT THAT WAY!
I understand oil viscosity in aviation oil is doubled, so a 30w auto oil is a 60w aviation?
As an aside,, I installed an Anti Splat oil separator and vapor extractor in my Grumman and last oil change I put in the full 8 liters.
At 60 hrs (overdue) I have added 1 liter and is now down to 7 liters!! This in an engine that used to be filled to the "normal" 6 liters and used a liter every 10 hrs??
As a second aside,,,I have a 2012 Lexus, I use synthetic oil, and change at 10k kilometers. We ran it over last change by a few thousand and the mileage went from 24mpg to 18. We stop at Mr Lube and the mileage immediately went back to 24mpg. The dash display indicated and confirmed (incredulously) by actual.
The car computer knows the mileage between oil changes,,we reset it. Is this Lexus screwing with me or is there something about oil out there I have been previously unaware of.
I hate unexpected results!
Ray Toews
Fort Vermilion AB
