Results 1 to 10 of 10
Thread: drag/antidrag wire conflict with ribs
    May 2014
    Putting together a Hatz CB-1 and am encountering some conflict with the internal brace wires and the ribs. I can displace the ribs a bit sure prefer equal spacing. I'll notice it the rest of my life even though it would probably be less than 1/2". Should I notch the rib elements and then reinforce them with some short beveled pieces of capstrip or move the ribs?
    Sarpy Sam
    Moving the ribs slightly is a much better solution than weakening them. You can move the adjacent ribs slightly so that you do not have one rib that looks grossly out of place.
    You write that like it's a bad thing!
    They say that perfect is the enemy of good, but that depends on what considers perfect. "Perfect" is unaltered ribs with a little offset, IMHO. And you can look at the minute change in spacing and smile, knowing that you used your brains to come up with a simple and effective solution to a design problem.
    Brrrmidji , Minne-SNOW-ta
    They say that perfect is the enemy of good, but that depends on what considers perfect. "Perfect" is unaltered ribs with a little offset, IMHO. And you can look at the minute change in spacing and smile, knowing that you used your brains to come up with a simple and effective solution to a design problem.[/COLOR]
    Well said... I'll second that...
    JAM
    cluttonfred's Avatar
    World traveler
    I hear you on that but I think that slight changes in rib spacing should solve your problem. In fact, knowing that there is usually less lift being produced the further you go out in span and assuming the the other ribs are not yet in place, you might even mess around with the spacing to have it increase steadily as you move towards the tip.
    Have you checked with other Hatz builders on how they have tackled this?
    Matthew Long, Editor
    cluttonfred.info
    crusty old aviator's Avatar
    Jun 2012
    You can't get here from there
    If shifting the ribs on the spars for wire clearance just doesn't sit well with your sense of order, and you do decide to notch any diagonals or verticals in your ribs, make sure you sister another piece of cap strip on the back side of the notch, the full length of the notched piece, and sandwich the two between two, full width strips of 1/16" birch or mahogany plywood. Leave your tack hammer and nails in the drawer, hold it all together with mild spring clamps, like clothes pins, and wipe up the squeeze-out that runs and drips. But first, follow Mathew's sage advice and check with the Hatz builders' group for their established fixes.
    Dec 2013
    I have notched built up ribs on two different homebuilts and I'm still alive to tell about it. It's done often and as long as you account for the lost material and glue a scab along side the notch only you will know. I would rather notch a diagonal over moving a rib. Thats two cents of information for free. good luck.
    Neil's Avatar
    Monroe, LA
    I wouldn't mess with the rib spacing. I had an issue the same as you on my Acro Sport II as an anti-drag wire centered a vertical. I just added a splint on each side and even let them run into the gussets for good measure.
    May 2014
    Thanks for the input guys. I ended up notching, laying in another piece of capstrip and scabbing on a piece of plywood on both sides. The ribs are evenly spaced! I'm happy!
    Sarpy Sam
    Jim Hann's Avatar
    Just for reference here is how my PA-22/20 wings handle it, they just bent the diagonal to clear. I wouldn't be worried with what you did!
    Jim Hann
    EAA 276294 Lifetime
    Vintage 722607
    www.mykitlog.com/LinerDrivr
    Fly Baby/Hevle Classic Tandem
