It is perfectly legal to drop things from an airplane. 91.15 Sec. 91.15 — Dropping objects. No pilot in command of a civil aircraft may allow any object to be dropped from that aircraft in flight that creates a hazard to persons or property. However, this section does not prohibit the dropping of any object if reasonable precautions are taken to avoid injury or damage to persons or property. So legally it can easily be done. The trick is to take every precaution to avoid creating a hazard and injury. Of course, if something happens, you clearly didn't take enough precautions and are guilty. So the big question is.... What is the venue? If it is at a house in the middle of a subdivision on a 1/4 acre - I'd say you are not going to be able to pull it off. You will have to be 1,000 feet above any congested area and the likely hood of you being able to hit a 1/4 acre property is pretty much nil. Now if it is on a ranch with big wide open areas.... Easy. You can put up a fence (rope, whatever) and keep the children behind it. Then fly in low and drop the candy from 500 feet into a big open field and you will have no issue legally or from a safety standpoint. Maybe the BEST course of action is finding out how cool your airport is and see if you can have the party there. It would make the candy drop easy and safe. And you could even let kids see real planes.
1996 Quad City Challenger CWS w/503 - Sold
1974 7ECA Citabria - Sold
1986 Pitts S1S
It's great fun, and we do it at our annual fly-in and at some parades, etc. Depending on the event, we fill a tennis ball can, oatmeal container (cardboard), etc. with both parachutes that use candy (tootsie rolls, hard candy, twizlers, etc.) as the "person" and paper helicopters with tootsie midgets as the weight (instead of a paper clip). As you can see, I can't figure out how to attach a picture, but just imagine an "Air Bike" that's trailing smoke and 100+ red, white and blue paratroopers coming out the back. One $1 plastic table cover, a little tape and string and a bag of candy will get you 64 paratroopers. I print 5 helicopters to a single 8.5" X 11" piece of plain paper ... good in black and white ... you can also advertise the event (or B-day party in your case) on the helicopters. If you need "plans", email me at fly-in-home@att.net and I'll be able to get them to you.
These work well with the children throwing them up from the ground, too.
Always fly safely ... take someone with you to empty the container (don't toss the container). And remember, as soon as you open the can, your paratroopers will start departing! :o)
Ron B. That is a great system!!!
They tried to reenact Gail Halvorson's DC-6 thing at one of our local airshows. The candy came down pretty far and wide over the airport.
