Originally Posted by
cub builder
You don't say the speed of your aircraft, but if it's fast and slick, you may very well overspeed the prop on a wind generator. They are fine for Champs, Cubs and Taylorcraft. Not so much on a slick airframe.
I've been seeing more and more people using a backup alternator mounted to the vacuum pump pad. In case of alternator failure, you minimize your electrical load if necessary and toggle over to your light weight backup alternator system. No need for a backup battery as you still have the capability to maintain your battery, and you have the capability of continuing your flight to your destination, and home again for repairs. In this scenario, a primary alternator failure is only an inconvenience, and not an emergency, or for that matter, not even an urgent situation unless your are flying at night and need more power than your backup alt can provide. Those with all LED lighting and strobes can usually get away with an 8 Amp dynamo system. Others can usually get by with a 20 amp standby alternator system.
B&C makes an 8 amp dynamo type standby alternator and 20 and 30 amp vacuum pump mount alternators. Either will mount to the vacuum pump pad and are priced in the $500 range. Plane Power has a 30 amp model that mounts to the vacuum pump pad, but is a bit higher priced.
-Cub Builder
