Moar brakes!
Okay, so while the camera battery recharged, I cut the steel stock, shaped the end, sanded, primed and painted it after drilling the holes for the band brake itself and the stabilizer bar.
Then I put it all together, measured the end bit sticking out, cut and drilled the end piece to keep the wheel on.
The stabilizer bar is some half inch thick walled tubing I had left over from my pile-o-scrap. Annealed, pounded, bent, trimmed and painted.
It came out as a pretty neat installation.
There's a metal sleeve over the bolt that goes through the brake strap to keep me from crimping it!
Now if the axel moves up on the bungees, the brake post moves forward. When the brake is applied, the stabilizing arm keeps it in place, slowing the wheel without turning the axel.
I bought the sleeves for the brake wire, the brake wire, and some end stops. The dual cable brake lever for the stick comes in on Friday.
Oh, on the other wheel mount I didn't have to move a thing - it was long enough on its own.
