Well, I did some of that today in a big way!
Let's build some rudder pedals!
I went with the pedals as per the plans versus a bar for a couple reasons - first, it's simpler.
But more importantly, they're humongerous pedals, and the only real Near Ground Loop I had was because my foot slipped off the Champ's pedals during a nasty gust just as I set down. I recovered it and didn't touch a wing to the ground, but there's no way that'll happen with these suckers.
Here's all the stuff one needs to make the pedals. The hammer isn't really needed, I just like having it handy to help with equipment attitude.
In the plans and in some kits there are two big holes cut out into the pedals, but mine didn't have them and I don't want them. I like to slide my whole foot on the floor to work the rudder, and don't want anything hanging it.
It's simplicity itself - five little tubes riveted to the sheet; four around the edges and one in the center. So I split the middle and drew a line with a pencil for that center tube. I even drilled the holes in the sheet first and then centered the tube on them to make sure I was on the mark.
Ready to close up the second rudder! Measuring the center tube was good business - I just made a pencil mark and hit it without pulling a rivet!
The important thing to remember was to drill and mount the connecting gusset for the rudder cable BEFORE putting on the other side!
Two rudder pedals done. The hinges that Robert included were pretty much standard door hinges, and they got wet during one of the times the roof to the wonder tent was ripped in two during a storm. They became two hunks of rust.
I got some beefy piano hinges, trimmed to length, and used them instead.
