Holy holes, batman! That's actually a thing of beauty, but my seat weight is in ounces and the back sheet metal will be compromised and just warp a bunch with a lot of holes in it.
My seat was too high. The shoulder straps would have to bend up from the turtle deck mount and would be a question mark if the unfortunate happened. But I can't lower it with the elevator rod in its original position. The solution came from another WWI replica builder with the same problem. He simply moved the mount point for the elevator control rod to the end of the column, which lowered it quite a bit. I borrowed from him liberally, as I have no shame.
Okay, here's the quick and dirty of how I adapted Bill's excellent modification for my own benefit, which was actually pretty straight forward.
Moving the elevator control rod back over the rear carry through lowers the clearance quite a bit - note the seat supports (the unpainted tubes) are now far above the control rod.
I had originally thought to use some big lift tangs, like Bill did, but they turned out to be too short for clearance; I think my aileron control horn sits higher than his.
But I had some extra blades used for the lower wing mounts, and they were more than longer enough (and quite thick and robust).
To keep them the same height as the control stick, I used the stick itself, drilling the hole for where it sits on the column and then using a AN3 pencil to mark where it hit the original elevator control rod mount point and drilling there.
I used the piece of the elevator control rod that was cut off originally (never, ever throw anything out!) as it was the right thickness and length, drilled a couple holes in it and shazam! the control rod is on a hinge in a solid linkage.
Trim, sand, and paint, and it looks beautiful.
What isn't shown is the fact that when I put that tube inside the elevator control rod as a sleeve I had riveted it in several places to make it to where it didn't slide around inside. So I drilled all those rivets, slid out the inner tube, measured it back, cut it to allow for the elevator control mount to slide in the main rod, and re-riveted it.
Then I cut the elevator control rod to fit after locking down the elevator in neutral position with a board and zip ties and putting the stick in center and re-drilled it. Amazingly I did all the above without messing it up.
Here's the seat with the new configuration with the front legs on the floor board...it clears the elevator control rod with a little to spare at this height, lowering the seat about four and a half inches. A squat test on the carry throughs without the seat puts my shoulders right at the top of the turtle deck, which was the goal.
Tomorrow I'll modify the seat to fit this, including mucking around with those rear supports - yea, more rivets to drill out - and hopefully finish it up.
