She's in rig!
It's been a tough winter for all of us, but with things improving she came out of the tent...
First, I need to back up a bit. One of the things I don't like is that the wires on the fuselage end go right onto the wing at the compression strut. I just had nightmares about trying to cover a wing with eight feet of wire attached at the inner compression strut, especially since my swagging tool (which I refer to as "that M-F'er") has a hard time fitting in tight spaces.
Yes, gentle reader, I have gone through many yards of wire and nicopress fittings due to the unforgiving go-nogo gauge to the point of embarrassment.
Here's my solution - two small extension plates made of mild steel for each end that will fit around the fixed mount and attach just like the turnbuckles.
I used one that I bought from Aircraft Spruce as a template.
All cut out and ready for some trim and drilling:
Ready for sand, prime and paint:
Each gets labeled on the aircraft with the appropriate mounting position. It worked really well and I couldn't find any extra play in the wires when I tried it both ways. Drilling in pairs ensured they were matches per wire.
So it was back out onto the grass under the frames I made from the boards for my build table, put into flying configuration, and leveled up. Mounting the wings was a fun thing by myself - my neighbor across from me, who has an unhindered view of my back yard, could be heard snickering at a couple places.
To ensure that things remain true, I double side taped some spirit levels to the wings. These were double checked from time to time to ensure the tape wasn't giving a false reading - but they were true the whole time:
The wings are held together using a thick aluminum plate that's bent to the required 14 degrees in the middle. This was a pain, as the bend needs to be centered. Again, the right curse words and they were locked down with a few bolts. It was nice to see the wing level over the joints.
The cabanes were easy as well. Using the Baslee "Just thread the bolt, mount the wires as tight as you can and then tighten the bolts" technique is genius.
Mounting the wing struts was surprisingly straight forward; I just put the lower wings on, checked the dihedral a couple thousand times, and propped the ends up with a lawn chair to hold them in place.
Then came the hell of wires. The video says to leave a couple threads on the turnbuckles, tighten as hard as one can, swag, and then tighten the turn buckles. This is both true and false. True in that it will make the wires tight enough.
False in that "as tight as one can" is subjective. Based on my anger level, I found I could put A LOT of tension on the wires to where it took the box of the wings into a trapezoid when tightened. One must think happy thoughts of circling clouds with the sun dappling on the river below; at least that worked okay for me. I pulled using a set of pliers and locked it down with some vise grips, then did the swag.
Also, order matters. Rear lower wing, rear upper wing (both sides), front lower wing, front upper wing - and she didn't warp up.
Suddenly, she's in rig as the light was fading!
Happiness is a spirit level on a wing showing a center bubble!
Loads more to do before she can get taken back apart, though. The wires need trimmed (I left the excess dangling), and with the upper wing mounted I can put in the aileron controls.
I didn't tell of all the hilarious errors, like crossing the wires the wrong way so that they bent around each other, getting it right and level to see that I had put the turnbuckle on the wrong end (do over!), or the hour I spend looking for the end of a turnbuckle in the grass (hint- they're ferrous and rare earth magnets are one's friend).
