Page 105 of 105 FirstFirst ... 55595103104105
Results 1,041 to 1,048 of 1048
  1. #1041
    Rather than a third edit, I'm trying to figure out why some pics are showing and some aren't. All of them are on the website server and display properly in Cpanel, but not as a link.
    I may experiment a bit to see if I can get them to work.
    [edit]
    The problem was that some of the photo files had a .JPG extension, which somehow isn't recognized as a photo; however, a lower case .jpg is fine and dandy. So I'm going through and manually renaming all the image files with an all caps JPG with a lower case jpg.
    This may take awhile.
  2. #1042
    Hi Frank,
    How's it going with the rebuild?
  3. #1043
    Frank, look for a free program called AF5Rename, it can do all kinds of mass renaming.
  4. #1044
    The upper case JPG signifies the file is 8 bit. This is unusual as when I had an 8 bit computer in 1994 the only image files were .BMP and .TIF. I am currently having some problems with .jpgs not opening in the stock photo app in Windows 10 but if I select edit first and display them, then then do open. Naturally, I have files that once were 16 bit, some 32 bit and now my file system and all working programs are 64 bit. Were you around when "long file names" became possible in Windows 95 in yes, 1995. I don't know about Apple. Until then all of the file names also were all caps. I truly appreciate the work of those who labor to keep legacy legible.
  5. #1045
    Quote Originally Posted by Saville View Post
    Hi Frank,
    Well, I've been slack on updating, but the fuselage is done. Well, minus turtle deck stringers, seat, controls, restraints, throttle, front side panels, wood floor, firewall, gear, covering and painting. But other than that, done.
  6. #1046
    Did a bit of artful beating on the cowl this morning! Sorry for the quality, my fllp phone is great at making phone calls, but not being a camera.
    http://eaaforums.org/attachment.php?...1&d=1599951567
  7. #1047
    Eric Page's Avatar
    Toledo, WA
    Wow, I would have called that part a write-off! A kiss of high-build primer, a little sanding, and it'll look like a bought one. Well done!
    Eric Page
    Building Kitfox Series 5
    Member: EAA, AOPA, ALPA
    ATP: MEL / Comm: SEL, Glider / ATCS: CTO
    Map of Landings
  8. #1048
    Hi Frank,
    Glad to hear you are making progress. When you have the time a picture of the fuselage in its present state would be great.
    But totally understandable if you are too busy for that.
    Thanks!
