Page 69 of 69 FirstFirst ... 1959676869
Results 681 to 686 of 686
  1. #681
    Spoke to Robert Baslee from Airdrome about my brake woes, and he is sending me a set of drum brakes to use instead of the band ones.
    I'll have to make custom backing plates, etc., but I've been down that road and have the templates for it.
  2. #682
    Hmmm, let's try this again.
    Prop hub on the crankshaft? Yep.
    Everything all lined up and the case put back together? Yep.
    After torquing the case nuts I stopped for the day. I was getting all scatter brained and started setting things down and forgetting where I put it and not finding things that were right in the open.
    Not a good way to be when I had the task of positioning piston rings and putting the pistons in the cylinders. Better to call it a day, drink some water, and get something to eat.
    I borrowed a bit from the instructions on the circle thingie that goes between the flat oil slinger and the prop hub. With it on the crankshaft I couldn't get a good view if the prop hub was fully seated or not when mounting it. It said that it could be split and the join rotated horizontally in the case once joined, so I did that.
  3. #683
    is that a Force 1 hub from GPAC?
    Great engine pics!
  4. #684
    It's not a Force One, but it is a shrink fit hub from Great Plains.
    They really are great. They went above and beyond in answering my questions, even in areas not covered by my purchase of a prop hub, crankshaft, bearings, and gasket set.
    A huge plus for a guy like me is that they speak do-hickey.
  5. #685
    I need a pinion removal tool to back out and re-align the distributor gear...I was off a tooth when I put the darned thing back together. It's on its way and should be here Tuesday or Wednesday.
    Then it's a matter of putting the bolt into the prop hub (Dave has it to drill a hole for the cotter pin), putting the Diehl case and starter on the back of it, putting the spark plugs in, mounting it on the engine, filling it with oil, and seeing if she'll start and adjust the timing.
    Getting closer....
  6. #686
    KDCU
    Frank, good to see your engine coming back together...it has been quite the journey!
    I see one item that you might want to consider. With "aviation engines" it is standard practice to NOT have any pressure senders mounted to the engine block. The concern is engine vibration might crack the threaded portion of the sender due to the weight of the sender fatiguing the brass threaded portion. This concern is alleviated by mounting the sender on the firewall and connecting it to the engine with a flexible hose. You may never have a problem with the sender as installed, but if it cracks you may be going through this overhaul thing again. The flexible hose is good insurance and easily installed.
    Here are the fuel and oil pressure senders mounted on the firewall of my RV-6:
    I would also drill a small hole in the oil filler cap so it can be safety wired. More cheap insurance.
    Best wishes for a successful engine break-in!
    Sam Buchanan
    EAA Technical Counselor
    The RV Journal RV-6 build log
    Fokker D.VII build log
