Page 103 of 103 FirstFirst ... 35393101102103
Results 1,021 to 1,025 of 1025
  1. #1021
    Yep, I'm fine.
    The medical part has been, um, challenging. Further scans revealed that I broke pretty much every non-floating rib on the left side, which is why it's taking so long to heal.
    Plus work. Sigh. Why in the world I agreed to working on aircraft is beyond me (okay, it was money), but they've really put me to work doing all manner of repair stuff, from resurrecting Cub ribs (terrible) to fabricating pieces (not so bad).
    Indeed, working at C&D (who restored the EAA sweepstakes Cub and are doing the 50th anniversary raffle plane) has increased my building skills tremendously - even though it was building the Nieuport that got me the job.
    To catch up, I've decided to just completely rebuild the fuselage - I'll use it for reference along with plans and my builder's log - reusing the controls, stuff on the dash, and a few other things.
    Sorry to hear about the busted ribs.
    Glad you decided to build a new fuselage.
  2. #1022
    There are many techniques for cutting thick aluminum sheeting for gussets.
    Some are clearly better than others:
  3. #1023
    When you go Up North , We're just North of that
    Hey Frank,
    When cutting longer lengths with my Makita Throatless Shear...
    I run a little of that waxy stuff... or put a drop of thin oil every 6 inches.
    Try it.
    bookmaker's Avatar
    Florida Panhandle
    Keep up the great work Frank. You'll be back in the air in no time.
    Dale
    Dale Cavin
    Florida Panhandle
  5. #1025
    My goal is rather than following the old saw of building three plane's worth of parts in order to make one, I'm just going to rebuild mine three times using just one part attempt each.
