Thought I would start a thread to discuss all things Bearhawk. I am going to start by adding some common links that us Bearhawkers use quite regularly.
Definition of the Bearhawk...
A four place high wing aircraft with excellent short field performance while retaining a good cruise airspeed that can be built by Scratch(Plans Only), Kit, or a combination of both.
http://www.bearhawkaircraft.com Home of the kits for the Bearhawk if you choose to go that route.
http://www.mybearhawk.com Eric Newtons site documenting his construction process of a scratch built Bearhawk.
http://www.bearhawkbuilder.com/ Map of all the different builders around the world
http://www.dreambuildfly.com Website of a couple of guys building a Bearhawk online so you can watch every Tuesday night.
http://www.bearhawkstore.com Store of all things clothing and memorabilia for the Bearhawk after you get hooked that it is the best plane to build.
http://groups.yahoo.com/group/Bearhawk/ The official email group for Bearhawk builders. You will find lots of support from this group during your build.
There are several more but these are the ones that I refer to the most. Feel free for others to add additional links and photos of your Bearhawk aircraft information to this thread.
