Hi, All;
I'm contemplating a Zenith 750 Cruzer kit. Aside from bugging the factory, one cannot join the Zenith discussion forums without a plans number.
I'm mostly interested in planes that have been (almost) completed with either an O-200 or Corvair engine. I'd like to know overall costs, avionics selections, kit completion, "gotchas", etc.
Specifically:
1. If you used an O-200, did you purchase the new "-D" model or an "A"? If the latter, did you select a used mid-time engine, one that was freshly overhauled, or did you overhaul it yourself?
1a. If you used a Corvair, which displacement option did you choose? Care to share what your engine build cost? (that will depend more on if you used a 5th bearing, WHICH 5th bearing, GM or billet crank, etc., so any build choices would be appreciated.
2. It appears that there is panel depth for a standard "tray mount" unit, like an SL-40, GTX-327, etc. True? How extensive is your avionics install? I'm under DFW Class Bravo, so I'll need an xpndr, but aside from that did you go with analog or EFIS type instrumentation. Brand selected, and why?
3. If complete, what is your empty weight? Did you paint?
4. The website says that the complete kit includes everything needed to build. Is that *really* complete, or do you need to purchase hardware? Cables? Supplies?
Thanks for any insight you might provide; if you'd be more comfortable taking this offline, please send a PM.
