Hal, maybe I missed it, but will there be an app this year? Thanks in advance. Glenn
Glenn Brasch
KRYN Tucson, Arizona
2013 RV-9A
EAA member since 1980
www.airportcourtesycars.com
Yes, it's in the final stages of testing now. As soon as we get the last bugs knocked down, we'll hand the iOS version off to Apple. From there, it just depends on how long their approval process takes. The Android version is following close behind.
Hal Bryan
EAA Lifetime 638979
Managing Editor
EAA—The Spirit of Aviation
If you need beta testers, there are a few of us here who would love to help.
Jeff Point
RV-6 and RLU-1 built & flying
Milwaukee, WI
"It All Started Here!"
Glenn Brasch
2013 RV-9A
Just downloaded the 2015 Airventure app to both my iPad and iPhone. Already adding forums to My Plan. I like the location map that appears when an item is selected. Don't like that you have to select the item and then > to find out what time it is scheduled. Items are listed chronologically, but must be selected to find out the specific time.
My schedule is already filling up! See you there! Pat
Downloaded the app. Looks good, BUT… is it possible that there is s host video or something somewhere that explains how to use it. Others here seem to have grasped it intuitively. I can probably figure most of it out, but I think I might miss out on a lot of what it can do without a bit of instruction.
Suggestion for the next revision. When looking at the Forums page for a particular day, sure would be nice to see the start time (without having to drill down for more info). Maybe at the start of the two line extended description. The same applies to the other "Attraction" sections.
I don't see the Warbirds Forums. Is there a reason for this -- or is the reason my inability to figure it out.
Chris,
Using a finger, drag down on the main screen to expose the search field. Then simply type "warbirds in review" into the search field and then tap "search". It will take you to all the warbird in review sessions.
Russ Zimmerman
EAA Member #292524
"Thanks Paul"
