Originally Posted by
Jazzenjohn
In 103-7 appendix 2 it calls out the dry empty weight in the calculation there, and I found this from FAA-8083-30_Ch04: Empty Weight: The empty weight of an aircraft includes all operating equipment that has a fixed location and is actually installed in the aircraft. It includes the weight of the airframe, powerplant, required equipment, optional or special equipment, fixed ballast, hydraulic fluid, and residual fuel and oil. Residual fuel and oil are the fluids that will not normally drain out because they are trapped in the fuel lines, oil lines, and tanks. They must be included in the aircraft’s empty weight.
You called it Marty. I can drain my oil bag, but I have to count the 15-20 ? ounces of oil in the engine sump because my motor mount stops me from being able to drain it, unless I modify it so I can drain it normally. I probably should do that anyway as it is a lot of old oil to leave in the engine at oil change time. Thanks for the quick reply!
