Thread: MZ201/202 engine
    Corona, CA
    MZ201/202 engine
    MZ201/202 • $3,200 • By Compact Radial Engines.
    60-62 hp, with special factory belt reduction; Gates Polychain belt - the lower power 201 version uses a multi-ribbed belt, this is designed to handle the higher power of the twin carb set-up.
    Brand new, never run, stored dry. Twin Bing carbs. Wiring harness, dual ignition modules, exhaust system, fuel pump, recoil start (can use electric). Lightest and simplest 60 hp set-up you can have. Nikasil cylinders. My design project outgrew this engine. Pick up preferred, but will ship at cost. • Contac
    or:
    Is this the 201or 202? How many bolts hold the reduction unit on?
    Tony
    Corona, CA
    The 201 and 202 are the same engine except for the accessories; the 202 uses twin carbs, fan cooling and gearbox, otherwise it's identical. This is basically a 202 with a specially made belt drive and free air cooling. You'd need a decent baffle set-up for cooling at high power settings, but if you prefer fan cooling the parts are available and easily installed.
    I'm pretty sure there are four bolts holding the reduction drive, I'd have to go the hangar to check.
    Corona, CA
    Five bolts hold on the reduction drive, Tony, I just checked.
    Quote Originally Posted by Aerco View Post
    Great you have the new design. I was not so lucky.
    Tony
    Still for sale?
    I see this is an old thread. Did you ever sell this engine?
    Brand new, never run, stored dry. Twin Bing carbs. Wiring harness, dual ignition modules, exhaust system, fuel pump, recoil start (can use electric). Lightest and simplest 60 hp set-up you can have. Nikasil cylinders. My design project outgrew this engine. Pick up preferred, but will ship at cost. • Contact Peter, located Cardiff By The Sea, CA USA • Telephone: 9
    or:
    PTairco@gmail.com
Size:  41.0 KBName:  20150513_123929_587x440.jpg
