Thread: MZ201/202 engine
Threaded View
    Corona, CA
    MZ201/202 engine
    MZ201/202 • $3,200 • By Compact Radial Engines.
    60-62 hp, with special factory belt reduction; Gates Polychain belt - the lower power 201 version uses a multi-ribbed belt, this is designed to handle the higher power of the twin carb set-up.
    Brand new, never run, stored dry. Twin Bing carbs. Wiring harness, dual ignition modules, exhaust system, fuel pump, recoil start (can use electric). Lightest and simplest 60 hp set-up you can have. Nikasil cylinders. My design project outgrew this engine. Pick up preferred, but will ship at cost. • Contac
    or:
