Originally Posted by
Marc Zeitlin
Yes.
When you get your operating limitations, they'll say something along the lines of "restricted to Day VFR unless properly equipped per 91.205 for night or IFR operation".
So you don't need to do anything other than make sure that the aircraft is equipped for whatever service you're going to use it for per 91.205 - no inspection necessary.
_IF_ something you do would be considered a "Major Change" per 21.93, you'd then need to comply with whatever your Operating Limitations said you'd have to do for a Major Change. Generally, a written notice to the local FSDO/MIDO and a response from them, plus 5+ hours back in Phase I.
