Good afternoon,
I have a Super Koala frame that I'm looking at completing. Simply put, if the frame is wood, what would I need to do in order to enforce the frame with carbon fiber fabric, or fiberglass instead of fabric covering?
I already have wings made up, and I plan on using a foam core with fiberglass on the exterior. This should give me a bit more strength, am I correct?
Weight issue aside (I am planning on adding a more powerful engine and adjusting a few more things to make it work), am I crazy or is this a viable option to creating a new aircraft?
Trevor
