Dear all
I decide to change the VW based engine in my J3 replica, to an original Continental.
A friend of mine had one disassembled Continental A75 and lots of parts missing.
I’ve had every part check for cracks and magnafluxed, i.e, crankshaft, camshaft, cylinders and camshaft gear, all the rest was brand new from Fresno Airparts.
All the measures and tolerances accords to continental manuals and I had crankcase check for bearings alignment and it was refaced even there was no problem , physical and chemical cleaned and alodined, every little detail had been checked.
After the first flight with 1.5 hour I’ve noticed that when turning the propeller, it creaks and it is kind of heavy !
After cooling down to room temperature it turns free without creaking.
From room temperature to creaking condition takes only 4minutes of running time.
Since so I’ve disassembled and reassembled the engines 3 times looking for something wrong, but every time all dimensions were correct and I couldn’t find anything wrong.
The oil pressure is 30 psi in idle and 60 to 55 psi in flight, the temperature is under 140F, it was 3 flights of 20 minutes each.
I take cylinders off 2 times more looking for wrong gaps, material or marks and nothing wrong again.
Since it is an experimental aircraft and I have lot of experience in mechanical, I’m doing the job with the help of an A&P, but we can’t find any reason for this creaking as you can see in the video attached.
Someone had ever had a problem like this before ? some clue will be welcome !
please see video https://www.youtube.com/watch?v=_pMMVGEj0Ro
Thank you all
E. Tasca
