Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Pilot's Bill of Rights 2
    TedK's Avatar
    May 2013
    Pax River MD
    Quote Originally Posted by rshannon View Post
    Tom, Assuming the proposed PBOR-2 is enacted, what is EAA's position concerning how new or revised regulations implementing Sec. 2 should affect current Sport Pilots? I would suggest that any SEL Sport Pilot should also have at least daylight VFR privileges in larger, faster "covered aircraft", as defined, without further qualification (and the option to pursue night and IFR qualification if desired.) For daylight VFR activity, there is no relevant difference between required training and PTS for SEL Sport Pilots and PPL's even now.
    Ron
    Ron- are you suggesting that Aircraft Sport Piots have a path to Certificated Aircraft for Day, VFR, Sport pilot WX flying without having to jump the hurdle of a Private pilot examination? Interesting thought!
    Ted
    Sequim WA US
    Yes. Other than lack of a medical, insofar as relevant to daylight VFR, the training and PTS for SEL sport pilots and PPL's are virtually identical, even now. (The differences in minimum dual hours are almost entirely due to non-daylight VFR activity. Sport pilots are also required to get controlled airspace operations training and endorsements separately -- for which there is no specific minimum time requirement -- but insofar as might be relevant to daylight VFR, that's it.) If PPL's are going to be allowed to fly heavier-faster-than-LSA aircraft (whether certificated or experimental) in daylight VFR without a medical, there's no reason SEL sport pilots should not also be able to do so. Put another way, the only reason SEL sport pilots have not been allowed to fly heavier-faster-than-LSA (etc.) aircraft in daylight VFR in the first place, has been lack of a medical cert. For daylight VFR activity there is, literally, no other meaningful distinction in the training and testing a licensed SEL sport pilot has already completed, to the same performance standards.
    It's interesting you pose the question of a further testing "hurdle" for sport pilots, as if there might be some need or justification. Why should sport pilots have to be tested again on turns around a point, short field takeoff's, etc., etc.? If PPL's were required to pass another test on all that stuff they did already, just to fly without a medical, they'd raise holy hell, and rightly so. Why should that be different for sport pilots? It's worth noting that, even now, sport pilots who wish to get a PPL receive credit for both time and subject matter of prior training. Should they really have to be tested on all that again just to fly bigger airplanes in daylight VFR? Why? Both PPL and sport pilot candidates can train in a J-3 Cub. The PPL can go on to fly a C-182 with a constant speed prop in daylight VFR without further regulatory requirements, yet the sport pilot cannot. If and when a medical is no longer a legitimate requirement for PPL's to fly those aircraft in daylight VFR, why should SEL sport pilots still be excluded from doing the same?
    Similarly, if PPL's will be allowed to earn and fly with an IFR rating without a medical, there's no reason SEL sport pilots shouldn't also be allowed to do so, by getting the same additional training and testing for an IFR rating as is now required of PPL's.
    Bottom line is that absent the requirement of a medical, convergence between the two classes of licenses will soon be upon us -- as it should be. After all, were it not for the overwheming success of the sport pilot program, today's medical reform movement for PPL's might not even be on the table.
    The PPL would need the additional endorsements in FAR 61.31(e) and (f).
    TedK's Avatar
    May 2013
    Pax River MD
    Perhaps I could of picked a better word but hurdle seemed a better choice than a word that would justify the additional bureaucratic hassle that goes from going from SP to PP.
    I too see it as a continuum from SP up to the point you go for a Commercial. At that point, the bar should be set high.
    Sequim WA US
    Quote Originally Posted by dougbush View Post
    The C-182 is not a complex aircraft because it doesn't have retractable gear. (The R182 and TR182 models do.) Retractable gear, flaps, and​ controllable pitch prop are required for an aircraft to be a "complex aircraft" [FAA Order 8710.3E] consequently subsection (e) does not apply to a C-182. You are correct that aircraft equipped with 200 HP or more require a high performance endorsement under subsection (f). In that respect, I overstated the argument, but the essence remains. Substitute a 180-HP Piper Archer, Aviat A-1C-180 Husky, 180 HP RV-7A... or whatever.
    Although I did, technically, overstate the argument (mea culpa), nevertheless if we're comparing apples to apples additional endorsements are not really the issue. If a medical certificate is no longer a legitimate distinction (indeed, if it ever was) then SP's should also be allowed to obtain additional endorsements for any of the above, whether complex, high performance, etc., same as PPL's -- even now, at least for daylight VFR. Today they are not even allowed to qualify for those endorsements.
  6. #16
    Sequim WA US
    Quote Originally Posted by TedK View Post
    Perhaps I could of picked a better word but hurdle seemed a better choice....
    No problem, and the commiseration is appreciated. I guess my purpose in using quotes around "hurdle" was just to highlight again, but from a different angle, that except for a medical, both licenses already require essentially the same hurdles, especially insofar as relevant to daylight VFR operation of many dozens of non-LSA aircraft.
    Fortunately, when applying for a PPL, SP's are supposed to get credit for dual hours and subject training already completed, at least on paper. However, as a practical matter, in addition to another round of bureaucratic hurdles, a CFI will need to sign off again on everything, not just the additional material, and SP's are again exposed to all the previously-conquered knowledge and performance hurdles in the second round of tests. Are those things a big deal? In expense at least, yes. Is the redundancy necessary or fair? IMHO, no.
