Thanks for everyone's input. The problem with the Zenith builders group is you need to be a PRESENT Zenith owner and/or builder to join the group. I am going to contact someone (he may be on this forum and not even know I am going to call) named "Buzz" from TN. Zenith recommended him to check out and fly the plane. The only quirks of the present owner is that the bird is pitch sensitive and yet the ailerons are the opposite. Landing is 60 to 65 knots.
