OK, I'm confused again. I thought every aircraft in Alaska was outfitted with ADSB to prevent midair collisions?
http://www.foxnews.com/us/2015/02/01...cmp=latestnews
It's only good if it's turned on and people are paying attention to it. The CAPSTONE units don't have the assertiveness of TCAS in screaming at the pilots.
I've always thought of ADSB as a precautionary tool in that it advises a pilot of aircraft that are in proximity of one's own - but only that. "Hey, there's an aircraft within three miles...two miles...one miles from you," letting one know to (and where to) look for it, much in the same way that a radio traffic call out at an uncontrolled airfield does.
ADSB will tell one where an aircraft is, but not where it's going. Even a track is historical and a predictive one would only be predictive.
Data and information are two different things, and as pilots we have to remind ourselves of it as we get more whiz-bangs.
A tachometer can tell us RPM's are dropping. The altimeter can tell us we're losing altitude. The throttle can tell us we haven't changed the setting. It's only by turning all of that data into information that gets us to pull the carb heat handle, as an example.
On Monday the FAA made a correction to the ADS-B rule that opens the door to non-TSO products that meet the requirements but have not been through the expensive TSO testing. This wording change is substantial. This might allow the manufacturers to make lower cost units, perhaps even hand-held ADS-B products, for the Experimental, LSA, even VFR GA low end aircraft. See more in the EAA News section.
EAA News article:
https://www.eaa.org/en/eaa/eaa-news-...wer-cost-ads-b
The non-TSO'd equipment must still perform like TSO gear. Therefore it must be tested. Therefore the manufacturer might as well apply for the TSO. What lower cost units?
Until the FAA changes the rule to allow non-ADS-B Out equipped airplanes to fly under the Class B layers inside the 30 nm veil, it's game over for many pilots and airplane owners.
Disagree. There are already units that are low cost that do ADS-B out. Skyguard TWX sells a transceiver for $1500:
http://adsb.skyguardtwx.com
While they are in the process of applying for a TSO (so therefore believe that they've met the technical requirements), this unit works (I know folks that have them), puts you into the system in what would be a legal manner and while not exceedingly cheap, is not out of line for avionics. It's MUCH cheaper than the current batch of TSO's units, which start around $3K - $4K, and the sky's the limit.
I imagine that many of the other ADS-B IN unit MFG's will add ADS-B OUT to their systems, especially if they know that the Exp. market is looking for this and the FAA explicitly allows it.
I don't think the FAA needs to do anything more than they've just done (and it's not even obvious they needed to do that, since, assuming the TWX system gets its TSO approval, there'd be a TSO'd unit on the market for $1500) to ensure that the game is not over for many pilots and owners.
Marc J. Zeitlin
marc_zeitlin@alum.mit.edu
www.cozybuilders.org/
www.burnsideaerospace.com
Copyright © 2024
Skyguard's web site says they will come out with a TSO kit once the TSO rules are complete. They don't claim to meet the TSO performance standard. However, I believe their equipment does meet the performance standard. Their TSO kit was to contain 1) an external mount antenna to replace the suction cup mounted ADS-B Out antenna, 2) the FAA TSO approved GPS puck (read high $$), and 3) a software patch that effectively sets a bit in the transmission stream to say it is a TSO approved unit. I'll bet their web site gets updated soon to reflect meeting the TSO standard.
With the FAA's correction to the rulemaking, if the unit itself meets the performance standard, it should be good to go for under $1000 for their ADS-B out only unit or <$1500 for an all in one unit.
Many manufacturers produce avionics for the E-AB and LSA markets and never bother to get a TSO. MicroAir, X-com, and Dynon are the first to come to mind.
Cub Builder
Yeah, they do. If you read their blog, they've submitted to the FAA twice now - the 2nd time in January. If they didn't believe that they met the standard, they wouldn't have submitted, because the paperwork is a PITA.
Soon is relative :-). They say that it's in the FAA's hands now, and they expect a 2nd round of request for more info, so I'd bet it's many months before approval.
I certainly hope you're correct.
Marc J. Zeitlin
Copyright © 2024
And this is the key to all TSO/non-TSO'd equipment.With the FAA's correction to the rulemaking, if the unit itself meets the performance standard, it should be good to go for under $1000 for their ADS-B out only unit or <$1500 for an all in one unit.
What's the difference between a TSO and a non-TSO'd vertical card compass? Two hundred dollars (or more). They both work the same, give the same results, and are both accurate in the exact same ways. But only one of them is legal to install into certified aircraft, which must have all certified parts in them in order to stay certified.
If there's a production line that produces the same product in the same way for the same company, why do those in the TSO bin at the end of it cost more? To cover the certification costs and in a little bit because they can. If one owns a C172 it doesn't matter if they're giving away non-TSO ADSB units with hats at AirVenture, he can't install it on his aircraft. He's going to have to pay whatever the market has agreed to price TSO'd ADSB units at.
Since us homebuilders are a largely optional market for stuff, they put a certain percentage of production at a reduced price out for us (and some companies forgo certification entirely in order to speed up production process times). Skyguard is doing this. They could hold up production and sales as they await certification or they can sell now as non-TSO while their sample products wind through the government process.
Either way the FAA doesn't care. If one has a functioning ADSB-out unit that's been properly installed and working they won't know it's not non-TSO'd and will be pleased that it's there.
