i had hoped the recent ADS-B rule change might permit nonTSO'd ADS-Bs to be used in Certificated Aircraft (similar to nonTSO'd AOAs) and queried the FAA. Unfortunately, that is not the case per the response I got back from the FAA. Posted below.
Ted
Regarding your recent inquiry (below) concerning the technical amendment of 14 CFR part 91.225:
“Would this permit a non-TSO'd ADS-B that met the "performance requirements" of the applicable TSO to be installed in a Certificated Airplane operated under Part 91?”
The ADS-B rule contained in §91.225 (as amended) does not change any existing regulatory requirement for alteration of a type certificated aircraft. An ADS-B transmitter (TSO-C166b or TSO-C154c, as applicable) installed on a type certificated aircraft through either a supplemental type-certificate or field approval must have been manufactured under an FAA production approval (TSO authorization) as required by 14 CFR §21.9(a)(2) and marked accordingly per §45.15.
Thank you for the opportunity to clarify the technical amendment to §91.225.
Regards,
James Marks
Aviation Safety Inspector (AC/AV)
ADS-B Focus Team Lead
Flight Standards Service
Avionics Branch (AFS-360)
Office
(202) 267-1707
